Slow FLASH programming with i.MX35 and S29GL01GP
    We have a custom HW equipped with Freescale i.MX35 processor and Spansion S29GL01GP NOR FLASH (1024x128kbyte sectors).
    For erasing and programming the FLASH we wanted to use our J-Link Pro interface.
    We could connect to the target correctly.
    When we tested the sector erase time, we got reasonable results (~87s for erasing 128 sectors).
    But when we wanted to program the FLASH, we experienced very low flashing speed: 474 byte/s.
    We performed speed test (IRAM, 128kbyte) which reported ~181 kbyte/s down and ~188 kbyte/s up speed.
    When we enabled the "Use target RAM" for IRAM and 4 KB, the RAM check timed out.
    After that we changed the RAM size to 1 KB. With this setting the RAM verification passed, but the subsequent erase / program operation timed out.
    Did anybody experienced such a slow flashing speed?
    If yes, did anybody find the reason behind that?
    The "Use target RAM" option seems to be useless.
    Did anybody use it with i.MX35 target?
    Gyula Kovacs
  • Hello kkb-tec,
    it sounds a bit like your project has a very low JTAG speed selected, such as 5KHz.
    Can you verify either in project settings or during operation in the control panel?
    Programming speed should be much higher.
    mecalac: NAND flash requires a so-called custom RAMCode since the connection between CPU & NAND differs from CPU to CPU and even from hardware to hardware using the same CPU.
    kkb-tech: Are you using an eval board or custom hardware? If you can provide us a hardware with CFI NOR flash which can remain at SEGGER we can implement high speed CFI NOR flash programming.
