Experience with GDBServer and NOR Flash
    I would like to add my experience with programming an external Spansion NOR Flash on NXP LPC2478.
    Be carefull during writting parameters to the GDB Server. I made a mistake the flash was 16MB and I set a lower address range -> 8MB
    (monitor flash CFI = 0x80000000-0x80FFFFFF). (Un)fortunately JLink software reads CFI info to perform write/erase timing and number of sectors etc. This led to a confusion of the JLink (GDBServer assumed 8MB, CFI 16MB) with a result: ERROR: Programming failed @ address 0x81000000 (item verification error).
    Based on this experience I assume you cannot virtualy divide the flash into two partitions, one for code 8MB, second for data.
    Best
    Martin
    [edit]
    corrected grammatical discrepancy
    Edited once, last by wella-tabor (February 16, 2013 at 4:19 PM).
  • Hi Martin,
    Quote
    J-Link MUST read the CFI information to get information about the sectorization.
    Quote
    Has been fixed in V4.62b
    http://www.segger.com/jlink-software.html
