I am reposting this from the other thread since that one is marked SOLVED.
I've had a lot of problems along these lines, and also a lot of great solutions.
I basically went through 3 phases with my nRF51822 Evaluation Kit board (PCA10001).
In phase 1, everything worked well, both with and without softdevice. I could use JLinkExe to download programs and I could use JLinkGDBServer with gdb to debug. This was with version 4.62, previous versions didn't work so well.
In phase 2, I could use JLinkExe to download programs using the si 1 and selemu commands first (without them it didn't work). However, the GDB server didn't work. The output was:
Connecting to J-Link...
Connecting to J-Link failed. GDBServer will be closed...
Restoring target state and closing J-Link connection...
Shutting down...
In phase 3, JLinkExe doesn't work even with si 1 and selemu. This is the output:
J-Link>selemu
J-Link[0]: Connection: USB, Serial number: 0, USB address: -257
Select emulator index: 0
DLL version V4.62, compiled Jan 25 2013 15:29:24
Firmware: J-Link OB-SAM3U128 V1 compiled Jan 7 2013 18:12:29
Hardware: V1.00
S/N: 480202242
VTarget = 3.300V
Info: Could not measure total IR len. TDO is constant high.
No devices found on JTAG chain. Trying to find device on SWD.
Info: Found SWD-DP with ID 0x0BB11477
No device found on SWD.
Did not find any core.
Failed to identify target. Trying again with slow (4 kHz) speed.
Display More
So it can connect to the debugger, but not contact the device.
Throughout these phases, I've always been able to use the "Recover" command in the latest version of nRFgo Studio.
My questions are:
1. Does anyone know a sequence of commands that does the same thing as Recover in nRFgo Studio?
2. Do you have any suggestions for how to get JLinkGDBServer up and running? I was thinking that I could put some commands in a script to be launched with JLinkGDBServer, but I'm not sure what the non-interactive version of selemu is.
