hi:
I have been writng code and test it on IAR evb with lpc2468 a few day. But after I download
code to the board this morning. My J-link lost communication with the MCU. I did learn some
from Forum today and knowing what casue the problem and tried to fix it by your J-FLASH
software. well, I am sorry that I still can not make J-LINK to connect to MCU. MCU is running
with no correct setting PLL or RCTK. How can I let your device (J-LINK) control the ARM cpu?
Is there any easy tool to ereas code in flash of MCU ? I do believe that a lot of people facing
same problem as I have today
Steve Tian
Here is the log
Fri Apr 04 10:47:58 2008: Loaded macro file: C:\Users\admin\Documents\IAR Embedded Workbench\ARM\NXP\LPC24xx\IAR-LPC-2468\USBMouse\config\Ram.mac
Fri Apr 04 10:47:59 2008: DLL version: V3.78b, compiled Dec 10 2007 17:56:48
Fri Apr 04 10:47:59 2008: Firmware: J-Link ARM V6 compiled Dec 03 2007 17:34:18
Fri Apr 04 10:47:59 2008: JTAG speed is using adaptive clocking (RTCK signal)
Fri Apr 04 10:47:59 2008: TotalIRLen = 4, IRPrint = 0x01
Fri Apr 04 10:47:59 2008: Halting CPU core
Fri Apr 04 10:47:59 2008: Resetting target using [url='http://www.segger2.com/mailto:BP@0']BP@0[/url].
Fri Apr 04 10:48:01 2008: Fatal error: JTAG Timeout during adaptive clocking: RTCK did not respond.
Could not find supported CPU core on JTAG chain
Session aborted!
Fri Apr 04 10:48:03 2008: Failed to load debugee: C:\Users\admin\Documents\IAR Embedded Workbench\ARM\NXP\LPC24xx\IAR-LPC-2468\USBMouse\RAM Debug\Exe\USBMouse.out
Steve Tian
Here is the log
Session aborted!
The post was edited 3 times, last by steve tian ().
