Hi all,
When I use J-Link 4.36g and Keil 4.22a to debug STM32F407, it seems that there're problems with AGDI.
If the CPU is running, adding variables to the watch window works fine, and the value column shows the correct value of variables. But if the CPU is halted, value column turns to "cannot evaluate", and I cannot add any variables to the watch window. Adding watch with "WS" command in command window gives "error 123: AGDI: invalid operation".
Is there any workaround for this problem ?
Thanks and Best Regards
