JFlashSPI not able to program a SPI-Flash
    • JFlashSPI not able to program a SPI-Flash
      Hello.
      Im trying to program a AT45DB321E SPI-Flash with J-Flash SPI.
      I use v7.96 and v8.18, but it's not possible to program the chip.
      Autodetect shows: AT45DQ321 with Flash ID: 0x1F 27 01
      Connected is a: AT45DB321E with Flash ID: 0x1F 27 01 (01 00)
      After autoconnect, the page size was: 256 Bytes and 0x4000 Numpages.
      With this settings, a Erase is not possible, so i change the settings to: page size = 512 Byte, 0x2000 Numpages.
      After this, J-Flash-SPI v8.18 can erase the chip (readback show's: all data filled with 0xFF)
      The problem is: if i try to program&verify my data to the flash, wrong data (99.9% of the data in AT45DB321 is: 0xFF) are in the flash, and a error message is shown:
      Verification failed @ address 0x00000000 (Read: 0x00, Expected: 0x42)
      Failed to verify target.
      Failed to program and verify target.
      Same error, if i use the autodetect settings with 256 Byte Page!
      I try to write:
      0x42 0x46 0x53 0x5F .... (1MB data contents)
      Readback after progam&verfify shows:
      0000_0000: 0x00 0xFF 0xFF 0xFF ...... 0xFF
      0000_0010: 0xFF 0xFF 0xFF 0xFF ...... 0xFF
      and so on until 0x000001FF
      0000_0200: 0x00 0xFF 0xFF 0xFF ...... 0xFF
      0000_0210: 0x00 0xFF 0xFF 0xFF ...... 0xFF
      0000_0220: 0xFF 0xFF 0xFF 0xFF ...... 0xFF
      and so on until 0x0000040F
      I tested it with 30MHz, 8MHz, 300kHz : always the same error.
      The SPI-Lines are ok: level is 0 .. 3.3V @ Clock, CS, DI, DO
      Reset is pulled to 3.3V, WP is pulled to 3.3V
      Power supply is stable @ 3.3V
      So my question: is it possible to program a AT45DB321E SPI-Flash with J-Flash-SPI
      and what settings should be used?
      attachment: read-Back from the chip (with wrong data)
      The post was edited 1 time, last by Forster ().
      The AT45DB321E can be configured with two different page sizes: 512 bytes and 528 bytes.
      J-Flash SPI only supports page sizes that are powers of 2.
      It is likely that your flash is configured with a 528-byte page size, which would explain why programming is not working.
      In J-Flash SPI, you can configure init steps (Project Settings -> Setup -> Init Steps) that are executed when connecting to the flash.
      I have attached a J-Flash SPI project that uses the init steps to change the page size to 512 bytes.
      Could you please test if this project works for your flash?
      Simon
    • Hello Simon.
      Many thanks for your help.
      I already had the same idea with re-initializing.
      Unfortunately this did not change anything.
      Even additional delays of 1ms after activating Chip Select and before deactivating Chip Select do not help.
      I tried again with your project file, but with the same failures.
      The AT45xxx is apparently not supported, or only with the 512Byte variant.
      As I currently only have 528 byte variants in stock, I am unfortunately unable to make any counter-attempts.
