[SOLVED] Data Breakpoint does not stop execution
  • [SOLVED] Data Breakpoint does not stop execution
    Dear all,
    i want to use the data breakpoint feature. As soon as data is written to a specific variable, Ozone should stop the execution.
    Inside watch, i see that the variable, the data breakpoint is assigned to, changes the values. But Ozone does not stop execution. See also attached screenshot.
    Can you please tell me what i'm doing wrong?
    Best Regards
    Dirk
  • Hi dirk.gehring,
    did you read the section 5.9 in the user's manual? Did you set all fields accordingly? Does your hardware support data break points? If so, could you please provide a J-Link log as well as an Ozone log recorded during the same session where you reproduced the issue?
    Creating an Ozone log is described in section 8 of the user's manual, creating a J-Link log is described here: wiki.segger.com/J-Link_DLL#Enable_J-Link_Log_File
    -- AlexD
