[SOLVED] How can I run and debug PIC(position intepended code) on ARM CM7 mcu from any address?
  • [SOLVED] How can I run and debug PIC(position intepended code) on ARM CM7 mcu from any address?
    I have PIC application for STM32F7xx mcu and want to run this application from any flash memory position and debug it in Ozone. The base address of code is 0x08080000 for the compiling time.
    For the first i used Project.RelocateSymbols:
    1. unsigned int Offset;
    2. int res;
    3. void OnProjectLoad (void) {
    4. Project.AddPathSubstitute ("***", "$(ProjectDir)");
    5. Project.SetDevice ("STM32F777NI");
    6. Project.SetTargetIF ("SWD");
    7. Project.SetTIFSpeed ("4 MHz");
    8. Project.AddSvdFile ("$(InstallDir)/Config/CPU/Cortex-M7F.svd");
    9. Project.SetOSPlugin ("FreeRTOSPlugin_CM7");
    10. //Offset = 0;
    11. Offset = 0x1000;
    12. Util.LogHex("Offset = ", Offset);
    13. res = Project.RelocateSymbols(".text", Offset);
    14. Util.LogHex("Offset res = ", res);
    15. File.Open ("***.elf");
    16. }
    17. void AfterTargetReset (void) {
    18. _SetupTarget();
    19. }
    20. void AfterTargetDownload (void) {
    21. _SetupTarget();
    22. }
    23. void _SetupTarget(void) {
    24. unsigned int SP;
    25. unsigned int PC;
    26. unsigned int VectorTableAddr;
    27. Util.LogHex("Offset = ", Offset);
    28. VectorTableAddr = Elf.GetBaseAddr();
    29. Util.LogHex("VT = ", VectorTableAddr);
    30. SP = Target.ReadU32(VectorTableAddr);
    31. Util.LogHex("SP = ", SP);
    32. if (SP != 0xFFFFFFFF) {
    33. Target.SetReg("SP", SP);
    34. }
    35. //PC = Target.ReadU32(VT + 0x04);
    36. PC = Elf.GetEntryPointPC();
    37. PC += Offset;
    38. Util.LogHex("Entry Point = ", PC);
    39. if (PC != 0xFFFFFFFF) {
    40. Target.SetReg("PC", PC);
    41. } else {
    42. Util.Error("Project script error: failed to set up entry point PC", 1);
    43. }
    44. }
    But there isn't any offset of code section in the output:
    1. Offset = 0x1000
    2. Project.RelocateSymbols (".text", 4096);
    3. Offset res = 0x0
    4. File.Open ("***.elf");
    5. ...
    6. Offset = 0x1000
    7. Elf.GetBaseAddr(); // returns 0x8080000
    8. VT = 0x8080000
    9. Target.ReadU32 (0x08080000); // returns 0x4, data is 0xFFFFFFFF
    10. SP = 0xFFFFFFFF
    11. Elf.GetEntryPointPC(); // returns 0x80A7034
    12. Entry Point = 0x80A8034
    13. Target.SetReg ("PC", 0x80A8034);
    14. .....
    15. Offset = 0x1000
    16. Elf.GetBaseAddr(); // returns 0x8080000
    17. VT = 0x8080000
    18. Target.ReadU32 (0x08080000); // returns 0x4, data is 0x20080000
    19. SP = 0x20080000
    20. Target.SetReg ("SP", 0x20080000);
    21. Elf.GetEntryPointPC(); // returns 0x80A7034
    22. Entry Point = 0x80A8034
    23. Target.SetReg ("PC", 0x80A8034);
    24. Memory map 'after startup completion point' is active
    This strange momemt: Elf.GetBaseAddr(); // returns 0x8080000. There is no offset.
    And code doesn't run properly, no any working brakpoints for example. I think, because there is offset of PC and it's working, but there isn't offset of code.
    When offset is zero the breakpoints is OK and application running without any probllem.
    Offset = 0;
    1. Connected to target device.
    2. Reset: Halt core after reset via DEMCR.VC_CORERESET.
    3. Reset: Reset device via AIRCR.SYSRESETREQ.
    4. Offset = 0x0
    5. Elf.GetBaseAddr(); // returns 0x8080000
    6. VT = 0x8080000
    7. Target.ReadU32 (0x08080000); // returns 0x4, data is 0x20080000
    8. SP = 0x20080000
    9. Target.SetReg ("SP", 0x20080000);
    10. Elf.GetEntryPointPC(); // returns 0x80A6034
    11. Entry Point = 0x80A6034
    12. Target.SetReg ("PC", 0x80A6034);
    13. J-Link: Flash download: Bank 0 @ 0x08000000: Skipped. Contents already match
    14. Offset = 0x0
    15. Elf.GetBaseAddr(); // returns 0x8080000
    16. VT = 0x8080000
    17. Target.ReadU32 (0x08080000); // returns 0x4, data is 0x20080000
    18. SP = 0x20080000
    19. Target.SetReg ("SP", 0x20080000);
    20. Elf.GetEntryPointPC(); // returns 0x80A6034
    21. Entry Point = 0x80A6034
    22. Target.SetReg ("PC", 0x80A6034);
    23. Memory map 'after startup completion point' is active
    So, I add TargetDownload function for bin file to the new address:
    1. void TargetDownload (void) {
    2. Util.Log("Downloading Program.");
    3. unsigned int VectorTableAddr;
    4. VectorTableAddr = Elf.GetBaseAddr();
    5. res = Target.LoadMemory("***.bin", VectorTableAddr + Offset);
    6. Util.LogHex("Load res = ", res);
    7. }
    And have the same result - there is no any working breakpoints and no normal running application from new address.
    1. Reset: Reset device via AIRCR.SYSRESETREQ.
    2. Offset = 0x1000
    3. Elf.GetBaseAddr(); // returns 0x8080000
    4. VT = 0x8080000
    5. Target.ReadU32 (0x08080000); // returns 0x4, data is 0xFFFFFFFF
    6. SP = 0xFFFFFFFF
    7. Elf.GetEntryPointPC(); // returns 0x80A7034
    8. Entry Point = 0x80A8034
    9. Target.SetReg ("PC", 0x80A8034);
    10. Downloading Program.
    11. Elf.GetBaseAddr(); // returns 0x8080000
    12. Target.LoadMemory
    13. Load res = 0x0
    14. Offset = 0x1000
    16. VT = 0x8080000
    17. Target.ReadU32 (0x08080000); // returns 0x4, data is 0xFFFFFFFF
    18. SP = 0xFFFFFFFF
    19. Elf.GetEntryPointPC(); // returns 0x80A7034
    20. Entry Point = 0x80A8034
    21. Target.SetReg ("PC", 0x80A8034);
    22. Memory map 'after startup completion point' is active
    When the offset is 0 all is OK. Application run OK, breakpoints working good.
    I can run another PIC code application from Eclispe from any address, for example with it's options in attachment - with offset of code 0x1000.
    And all is OK, code running and all breakpoints are working.
    But my main PIC project isn't created in Eclipse and I can't using Eclipse for debugging. The Ozone is good choise for me in this situation.
    So, can I run and debug PIC code application in Ozone such as in Eclipse drom any address? Now I can run and debug this application only without code offset.
    The post was edited 3 times, last by Aleksei ().
  • Hi Aleksei,
    I need to admit I do not yet fully grasp what you intend doing. Therefore, at this point in time, I can provide just some general thoughts.
    It appears to me that you intend changing the execution address range of your application so it differs from the place that is specified in the ELF file. In that case you need to tell Ozone where to find code by invoking `Debug.ReadIntoInstCache()`. It appears to be the case that this is not yet done in your setup. For details please refer to section 5.15 in the Ozone user's manual. There is also an article in our knowledge base which might provide useful background information: kb.segger.com/Ozone_Debug_and_Trace_with_RAM_Functions.
    Does that help in getting you up and running?
    -- AlexD
