[SOLVED] Does J-Flash skip writes 0xFF if the all of one block data are 0xFF at WorkFlash of Traveo2?
  • [SOLVED] Does J-Flash skip writes 0xFF if the all of one block data are 0xFF at WorkFlash of Traveo2?
    I try to write 0xFF to WorkFlash of Traveo2 MCU to avoid the ECC error by using J-Flash.
    But I got verify error after write 0xFF to WorkFlash. (See attached JFlash.log line 151-158, 302-309)
    Test case1 : All WorkFlash area is 0xFF.
    address 0x14000000 - 0x14017FFF are 0xFF.
    -> Verify Error at address 0x14000000.
    Test case2 : Part of WorkFlash area is 0xFF.
    address 0x14000000 - 0x1400FFFF are 0x01(not 0xFF data).
    address 0x14010000 - 0x14017FFF are 0xFF.
    -> Verify Error at address 0x14010000).
    Q1:Does J-Flash skip writes 0xFF if the all of one block data are 0xFF at WorkFlash of Traveo2?
    According to above test result, it seems that the J-Flash skip the 0xFF writing, if all of the one block data is 0xFF.
    Q2:If Q1 is YES, Can I write 0xFF to WorkFlash of Traveo2 by J-Flash?
    J-Flash Version : V8.10c, V8.10b, V7.98c
    Target MCU : Infineon CYT2B73CAD
    I attached my test environment. To know the detail refer to this files.
    T2GDownload.jflash
    JFlash.log
    • T2GDownload.jflash
      (2.22 kB, downloaded 943 times, last: )
    • JFlash.log
      (15.06 kB, downloaded 1,250 times, last: )
    By default, J-Flash skips writing 0xFF to an erased area when the erase value is also 0xFF.
    You can disable this option by unchecking "Skip Blank Data" under Options -> Project Settings -> Performance.
    Simon
