New
Hello;
I try to program renesas R7FA2L1AB via Flasher Compact.While programming stage ;
if i get "****** Error: Verification of RAMCode failed @ address 0x20000344." error , i get the verification error at the end of programming
If this happens once, I keep getting verification error.
If i dont get an error like that,the programming and verification phase complete without any error.
I use this script while programming
"eoe 1
usb 0
si SWD
power on
r
h
loadfile test.hex
qc
You can see the log below.
Do you have any idea?
Thanks.
SEGGER J-Link Commander V7.20 (Compiled Apr 28 2021 17:35:36)
DLL version V7.20, compiled Apr 28 2021 17:34:08
J-Link Command File read successfully.
Processing script file...
J-Link Commander will now exit on Error
Firmware: J-Link / Flasher Compact V5 compiled Mar 30 2022 10:20:21
Hardware version: V5.00
S/N: 1015000945
License(s): JFlash, GDB
VTref=4.779V
Selecting SWD as current target interface.
Target connection not established yet but required for command.
Device "R7FA2L1AB" selected.
Connecting to target via SWD
Found SW-DP with ID 0x5BA02477
DPIDR: 0x5BA02477
AP[2]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x74770001)
AP[1]: APB-AP (IDR: 0x44770002)
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0x4001A000
CPUID register: 0x411CD200. Implementer code: 0x41 (ARM)
Found Cortex-M23 r1p0, Little endian.
FPUnit: 4 code (BP) slots and 0 literal slots
Security extension: not implemented
CoreSight components:
ROMTbl[0] @ 4001A000
ROMTbl[0][0]: E000E000, CID: B105900D, PID: 000BBD20 Cortex-M23
ROMTbl[0][1]: E0001000, CID: B105900D, PID: 000BBD20 DWT
ROMTbl[0][2]: E0002000, CID: B105900D, PID: 000BBD20 FPB
ROMTbl[0][3]: 40019000, CID: B105900D, PID: 000BBD20 MTB
Cortex-M23 identified.
Reset delay: 0 ms
PC = 0002FA60, CycleCnt = 00000000
R0 = 20000B58, R1 = 000000FD, R2 = 0000001F, R3 = 000000FD
R4 = 000000FD, R5 = 000000FF, R6 = 20005580, R7 = 00000000
R8 = 0796202C, R9 = 379F0769, R10= 5BD0601E, R11= 8F22E2F3
R12= 00000C90
SP(R13)= 200055F0, MSP= 200055F0, PSP= 79BA0908, R14(LR) = 00003E63
XPSR = 81000000: APSR = Nzcvq, EPSR = 01000000, IPSR = 000 (NoException)
CFBP = 00000000, CONTROL = 00, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 00
FPU regs: FPU not enabled / not implemented on connected CPU.
Without any give address range, Erase Chip will be executed
Erasing device...
Write: 0x6AF0FFF1 D0F92800
Read: 0xB5F0FFF1 D0F92800
Failed to prepare for programming.
Failed to download RAMCode!
ERROR: Erase returned with error code -1.
Script processing completed.
"eoe 1
usb 0
si SWD
power on
r
h
loadfile test.hex
qc
Thanks.
S/N: 1015000945
VTref=4.779V
DPIDR: 0x5BA02477
AP[0]: Core found
Reset delay: 0 ms
R12= 00000C90
Erasing device...
The post was edited 1 time, last by mutlukosemen ().
