Plugin to modify or send data to Timeline view?
    • Plugin to modify or send data to Timeline view?
      New
      Is is possible to use the plugin or JS scripting engine to send data into the "Timeline" window?
      The application is for real-time plotting of a signal.
      In this application, the values of the signal have to go through a hardware FIFO, so they only exist in bursts in an array.
      Although, in this case, each sample *is* timestamped.
      So, if I could highjack the drawing in Timeline,
      and trigger updates on specific PC matches (or some other trigger mechanism), that would work great.
      It would just be a little bit of code to draw the `(t,y)` points, rather than trying to observe `y` as it rapidly changes withing the burst.
    • New
      Hi apullin,
      thanks for your inquiry. Ozone does not provide such a feature.
      -- AlexD
