emNet Berkeley (BSD) socket compatibility
    • emNet Berkeley (BSD) socket compatibility
      i am currently in the process of porting a OPC UA Stack to emNet.
      I am struggeling with the fact, that emNet isn't fully Berkeley socket compatible.
      For example the function setsockopt() doesnt support many hints:
      • IP_MULTICAST_LOOP
      • IP_MULTICAST_IF
      • IP_ADD_MEMBERSHIP
      • IP_DROP_MEMBERSHIP
      Those are all functions related to Multicast.
      IF i understand right, I can mimic the IP_ADD/IP_DROP_MEMBERSHIP options with the emNet Functions IP_IGMP_JoinGroup()/IP_IGMP_LeaveGroup().
      Am i right with this assumption? Are there any possibilitys for the IP_MULTICAST_LOOP/IF option?
      Henrik
    • You are correct, we are almost Berkeley compatible but not up to 100%.
      You can use IP_IGMP_JoinGroup()/IP_IGMP_LeaveGroup() as a replacement for IP_ADD_MEMBERSHIP and IP_DROP_MEMBERSHIP.
      At the moment there is no alternative for IP_MULTICAST_IF, we are currently working on a new feature which would allow SO_BINDTODEVICE, which in turn would allow you to do something similar to IP_MULTICAST_IF, you can force a specific socket to use a specific interface.
      For IP_MULTICAST_LOOP there is no alternative currently.
    • Hi Hendrik,
      you could use gethostbyname() or if you already have the host as an IP use the IP directly. There is a utility function to help you with that - IP_IPV4_ParseIPv4Addr()
      i have another question:
      What is the preffered way to bind a socket to a specific Interface?
      Background:
      We want to have several VLAN-Interfaces and want to send traffic from different applications in different vlans.
    • Hi Hendrik,
      since emNet V3.58.0 the setsockopt() option SO_BINDTODEVICE is supported which allows you to bind sockets to a particular interface.
      thanks for your help! The option SO_BINDTODEVICE is what we were looking for!
      Is there any example Code on how to receive Multicast Packets with emnet?
      We are currently trying by first calling:
      IP_IGMP_AddEx(vlan1_iface);
      And then:
      IP_IGMP_JoinGroup(vlan1_iface, 0xE0000016);
      But if we then receive a Multicast Message with this destination address, the packet gets
      dropped, because the function "IP_UDP_OnRxIP4" can't find a socket, that matches this multicast-address.
      Henrik
    • Hi Henrik,
      I'm not familiar with your code, did you open a socket afterwards? The IP_IGMP_JoinGroup() only joins the IGMP group and does not take care of this, you'd still have to do this yourself.
      Besides using sockets, it would also be possible to call IP_UDP_Open() after joining the group ( e.g. like IP_UDP_Open(0L /* any foreign host */, 0, ECHO_PORT, _OnRx, NULL); ) and then handle received packets on that port in the _OnRx callback.
      Jannik
