Jflash program error
  • Jflash program error
    Hi forum users,
    When flashing xmc4200-256 device I get program error with with address indication in RAM. Bellow is log output.
    When flashing through debugger all works fine. Anybody could help me how to solve this problem?
    rum
    Executing init sequence ...
    - Initialized successfully
    - Target interface speed: 4000 kHz (Fixed)
    - Found 1 JTAG device. Core ID: 0x2BA01477 (None)
    - Connected successfully
    Programming target (98904 bytes, 2 ranges) ...
    - Checking if selected data fits into selected flash sectors.
    - Start of preparing flash programming
    - End of preparing flash programming
    - Start of determining dirty areas in flash cache
    - End of determining dirty areas
    - CPU speed could not be measured.
    - Start of flash programming
    - Programming range 0x0C000000 - 0x0C00FFFF ( 1 Sector, 64 KB)
    - ERROR: Programming failed @ address 0x1FFFCF54 (program error)
    - End of flash programming
    - ERROR: Program failed
    - Start of restoring
    - End of restoring
    - ERROR: Failed to program target
    Disconnecting ...
    - Disconnected
