[SOLVED] JLink flash failure when using Ozone: Timeout while erasing sectors, RAMCode did not respond in time!
  • [SOLVED] JLink flash failure when using Ozone: Timeout while erasing sectors, RAMCode did not respond in time!
    I have a new failure when using 'Reprogramming Flash' from Ozone with my STM32 app. This started occurring about two weeks ago for me, was not an issue prior.
    Does not reproduce with same JLink, same STM32 device, same code, same process when connected to MacBook running MacOS 15 Beta running on M1 Max.
    macOS Sonoma 14.6.1 running on Apple M1 Ultra
    Ozone V3.34a
    JFlash V7.98c
    J-Link Compact PLUS V12.00 w/ Firmware 2024 Jul 18, SN = 852000910
    Note: I have deleted and reinstalled both Ozone and JLink tools, same behavior. I have compared JLink/Ozone preferences between the two different Macs and don't see a preference/setting in difference.
    [0][6]: E0043000 CID B105900D PID 005BB906 CTI
    Connected to target device.
    J-Link/J-Trace serial number: 852000910
    Elf.GetBaseAddr(); // returns 0x8000000
    Target.ReadU32 (0x08000000); // returns 0x4, data is 0x20030000
    Target.SetReg ("SP", 0x20030000);
    Elf.GetEntryPointPC(); // returns 0x8001928
    Target.SetReg ("PC", 0x8001928);
    J-Link: Flash download: Bank 0 @ 0x08000000: Skipped. Contents already match
    Failed to erase sectors.
    Programming failed (error code = 1) for block @ address 0x08007000 (0)
    Memory map 'after startup completion point' is active
    Programming failed (error code = 1) for block @ address 0x08002000 (1)
    T-bit of XPSR is 0 but should be 1. Changed to 1.
    Debug.Stop();
    Timeout while programming sector, RAMCode did not respond in time!
    OnDisconnectTarget() start
    OnDisconnectTarget() end - Took 8us
    Disconnected from target device.
    The post was edited 2 times, last by JayTT ().
  • FYI, after trying many things to find the difference, the one that worked in the end is going into the source tree and running:
    1. git clean -f -x -d
    to completely purge the build output directory and rebuild.
