[ABANDONED] Ozone terminal unable to send CRLF
  • [ABANDONED] Ozone terminal unable to send CRLF
    I have a project that does PRINTF and getchar using semihosting. The system works well with MCUXpresso tools from NXP. When i try do load and debug the executable in Ozone, I run into a weird issue.
    When i hit enter key, the MCU get 0 as input (not 0x0D) as expected. I tired different options in terminal window (like newline input termination format etc etc). Am I missing something ?
  • Hi SyamK,
    Which Semihosting service do you use? I assume, this is ReadC(). Is that correct?
    ReadC() returns a character. If you configure Ozone such that a dialog opens to enter a character, you need to enter a character and then click on the "OK" button. As a result, the character will be sent to the target. If you do not enter a character but click onto the "OK" button directly, an error is raised. I assume that this error results in a NULL character arriving on the target.
    Hitting the enter key in the dialog will have the very same effect as clicking onto the OK button.
    So hitting the enter key just tells when you finished editing, but it is not part of the information to be transferred to the target.
    Does that answer your question?
    -- AlexD
