The latest version of the Ozone Debugger fails to connect to the NXP S32K344 microcontroller. This can be reproduces with the sample project from wiki.segger.com/NXP_S32K3xx#Streaming_trace NXP_S32K344_TracePins.zip
Open the project with Ozone V3.32 and connect -> Works, open the project with Ozone V3.32a and connect -> Fails.
I am using an older j-Trace Pro for ARM Cortex-M (Part No. 8.18.00) and my operating System is Windows 10 Professional.
This is the Console output with the failing connection:
- Device "S32K344" selected.
- ConfigTargetSettings() start
- ConfigTargetSettings() end - Took 40us
- InitTarget() start
- SDA_AP detected
- Checking if debug access is already enabled...
- Core already enabled
- Checking if HSE firmware is installed...
- HSE firmware not installed
- Checking if Cortex-M7_0 and Cortex-M7_1 are operating in lockstep mode
- Lock step mode enabled
- InitTarget() end - Took 1.85ms
- TotalIRLen = 8, IRPrint = 0x0001
- JTAG chain detection found 1 devices:
- #0 Id: 0x0996001D, IRLen: 04, JTAG-DP
- Found 1 device in JTAG chain, IRPost/DRPost != 0. Reset IRPost/DRPost to 0.
- DPv0 detected
- AP map detection skipped. Manually configured AP map found.
- AP[0]: MEM-AP (IDR: Not set)
- AP[1]: APB-AP (IDR: Not set)
- AP[2]: MEM-AP (IDR: Not set)
- AP[3]: MEM-AP (IDR: Not set)
- AP[4]: AHB-AP (IDR: Not set)
- AP[5]: AHB-AP (IDR: Not set)
- AP[6]: MEM-AP (IDR: Not set)
- AP[7]: MEM-AP (IDR: Not set)
- AP[3]: Skipped. Not an AHB-AP
- Attach to CPU failed. Executing connect under reset.
- Failed to power up DAP
- Connect failed. Resetting via Reset pin and trying again.
- ConfigTargetSettings() end - Took 36us
- SDA_AP detected
- Debug access is not enabled yet. Performing enable debug access sequence...
- Debug access enabled
- InitTarget() end - Took 10.5ms
- DPv0 detected
- ConfigTargetSettings() end - Took 27us
- SDA_AP detected
- InitTarget() end - Took 10.3ms
- DPv0 detected
- ConfigTargetSettings() end - Took 28us
- SDA_AP detected
- InitTarget() end - Took 11.8ms
- DPv0 detected
- Connection failed.
