Systemview not able to connect to an STM32H7 / STM32U5 target
    • Systemview not able to connect to an STM32H7 / STM32U5 target
      Hi all,
      I have an application deployed on multiple targets. (Systemview Sources 3.54, PC Application 3.52a)
      On hardware with STM32F4 & L4, all is well.
      I've recently added boards with an STM32H7 & U5 and I can't seem to reliably connect via Systemview.
      Case 1:
      If I previously had a debugger (GDB) attached, the Systemview log shows
      -> JLink: T-bit of XPSR is 0 but should be 1. Changed to 1.
      -> Warning: Target is halted. SystemView Buffer might not be available, yet.
      No connection can be established.
      Case 2:
      If I power on the device (no GDB attached),
      -> I get a "DAP error while reading AIRCR" popup
      Afterwards, SystemView works just fine.
      Case 2 works only once per power cycle, if I try to connect again, it causes a reset on the target system.
      Does anyone have an idea what causes this behavior?
      Manuel
