[SOLVED] Segger RTT via Telnet
  • [SOLVED] Segger RTT via Telnet
    Hi
    Following up on a previous thread with the same title, I have the following scenario:
    I have a telnet client in order to collect RTT output for unit testing.
    In order to open the JLink telnet server, as I understand it, I first need to create the server, for example by connecting to the target first:
    JLinkExe -NoGui 1 -CommandFile ./connect.jlink
    1. > cat connect.jlink
    2. device ATSAMD21G18A
    3. si SWD
    4. speed 4000
    5. connect
    This connecdts to target and keeps the connection open.
    I then run commands likes this:
    JLinkExe -NoGui 1 -CommandFile ./test_rgb.jlink
    1. > cat test_rgb.jlink
    3. si SWD
    4. speed 4000
    5. connect
    6. exec SetCompareMode = 0
    7. loadbin .pio/build/test_rgb/firmware.bin, 0x2000
    8. r
    9. q
    This works, but I wonder if this is supposed to be the way to use third-party applications to interact with RTT.
    There must be a simpler way ?
    Kind regards
    Peter
  • Not sure what you mean with “There must be a simpler way”.
    What do you have in mind?
    Can you describe the “simpler” setup you have in mind?
    As RTT goes through the debug interface, you need an active debug session that does all the RTT handling and you can attach to via TELNET.
  • Hi Alex
    The optimal way for me would me:
    - upload the firmware
    - while doing so, start the telnet server
    - disconnect from the target, but keep the telnet server open
    - let me connect to the telnet server to interact with the target (testing)
    - let me upload firmware again, without stopping the telnet server.
    maybe this is something that could be achieved with your SDK ?
    Kind regards
    Peter
  • Hi Peter,
    First of all:
    As Alex pointed out, an active debug connection is mandatory for RTT to work.
    If you are wondering why, please refer to the following article:
    wiki.segger.com/RTT
    This does not change regardless of how you retrieve the data (via TELNET channel or via SDK API calls).
    I assume you are referring to programming the target device, correct?
    From your message it is not clear to me how exactly you are doing this,
    but I would further assume that it is either with J-Link Commander, J-Flash, or the SDK correct?
    If so:
    All of these provide the option to not disconnect on programming completion.
    You could use this option to keep the connection alive while you are using RTT via the TELNET channel.
    As mentioned, it will not allow you to use RTT without an activte debug connection (this is physically not possible).
    However, you could of course combine all steps using it:
    - Connect to the device
    - Flash Application
    - Read / Write via RTT
    - Disconnect from the device
    Does this answer your questions?
  • Hi Fabian
    I apologize if my wording is not precise, I am new to this field.
    Yes, with "uploading the firmware" I mean programming the device.
    And I am using JLinkExe on Linux to do this with a JLink plus compact.
    What I am doing is a kind of unit testing:
    - compile and build the test ( I use platform.io and VSCode)
    - upload the binary with the following commands:
    > /usr/bin/JLinkExe -NoGui 1 -CommandFile ./upload.jlink
    > cat ./upload.jlink
    device ATSAMD21G18A
    si SWD
    speed 4000
    connect
    exec SetVerifyDownload = 0
    loadbin .pio/build/target_test_wm_min/firmware.bin, 0x2000
    r
    h
    q
    Note that I quit (q) the connection at the end to be able to do this over and over again.
    After the upload, I run the unit tests:
    - connect to the telnet server with a telnet client
    - interact with the target via RTT.
    - reset the target
    - next test ....
    All this works very well and fast, and I am very pleased. Embedded programming starts to look like Java desktop.
    BUT: As I understand it, for this to work, I need to open _another_ connection (lets call it perma-connection) to the target that I keep open indefinitely ( until I stop work on the project)
    > cat ./connect.jlink
    device ATSAMD21G18A
    si SWD
    speed 4000
    connect
    Note that there is no q at the end.
    So during target programming I have to parallel connections, during unit testing with the telnet client I use only the perma-connection to maintain the telnet socket.
    Sorry if this sounds contrived.
    As far I understand you, there is no way around this. I need the perma connection to stay open in order to be able to connect to the server.
    Kind regards
    Peter
  • Hi Peter,
    This is correct.
    As long as you want to use RTT, you will have to have an active debug connection.
    Otherwise it is not possible to retrieve the RTT data from the target.
    However..
    ...this is not entirely correct.
    Yes, you need an active debug connection for RTT, but you could simply continue using the J-Link Commander session used for the application download.
    Example:
    1. device ATSAMD21G18A
    2. si SWD
    3. speed 4000
    4. connect
    5. exec SetVerifyDownload = 0
    6. loadbin <TestApp1>.bin, 0x2000
    7. r
    8. g
    9. //
    10. // Do RTT test 1 here...
    11. //
    12. loadbin <TestApp2>.bin, 0x2000
    13. r
    14. g
    15. //
    16. // Do RTT test 2 here...
    17. //
    18. //...
    19. q
    Note:I removed the "h" because reset implicitly halts the device & the device is released from reset on "q" anyway.
  • Thanks Fabian
    This is exactly what I meant with "simpler way", sorry for the roundabout nature of my question.
    I didn't realize that you can continue to do loadbin ... without a prior connect.
    Kind regards
    Peter
  • Hi Peter,
    No worries! :)
