[SOLVED] No function names on MacOS
  • [SOLVED] No function names on MacOS
    I've been trying to evaluate SystemView for a client. So far, I've been unable to fully use the SystemView application; everything seems to work fine, but functions are called function #xxx. I enter a function #167, then enter a function #43, and so on. I've followed a few tutorials on how to be able to send the data, but never managed to get it up and running. Yesterday, I had to whip out the Windows laptop for some firmware upgrades, and surprisingly, everything worked immediately. The function names were there, and when I opened up an example, the function names were there too (this isn't the case on MacOS; even on the examples, there is no function name). Both systems are running v3.52a.
    Does anyone have something similar?
    At first glance it seems like the description file could not be found when using MacOS.
    Are there any messages regarding this in the log window?
    In case it cannot be found the expected path should be written there, so you may simply copy the file to the expected location.
    SebastianB
  • And that has indeed fixed it.
    The log looked like this:
    1. 17:24:08 - Loading /Applications/SEGGER/SystemView_V352a/Sample/FS_DeviceActivity.SVDat
    2. 17:24:08 - TRACE START Event recorded.
    3. 17:24:08 - Warning: No description file found for embOS.
    4. 17:24:08 - Warning: Description files can be stored at /Users/jlangbridge/.config/SEGGER
    5. 17:24:08 - Warning: No description file found for emFile.
    6. 17:24:08 - Warning: Description files can be stored at /Users/jlangbridge/.config/SEGGER
    All of the files are available in the installation folder (Applications/SEGGER/SystemView/Description), but SystemView doesn't look for them in that folder. Instead, it looks at my home folder (/Home/<user>/.config/SEGGER/). The only file present was .SEGGER SystemView.ini which makes no reference to any files other than previously opened files. Once I copied the files over, it's all good, and I finally understand what my board is doing.
    Many thanks!
