Test Automation and GUI-Server Issue
  • Test Automation and GUI-Server Issue
    we have basically same commandline for two different controllers: psoc and MKV5x
    Commandline:
    $(flash_jlink_exe) -CommandFile $(flash_jlink_path_set) -Log $(flash_jlink_log)
    you can find commandfile and output in the attachments.
    The Problem is, that mkv5x is not flashed, instead it keeps hanging at the gui-server...
    even more problematic is, that no pop up or whatever shows up...
    same for jlink 7.64 and 7.90
    But for 7.90 there is one difference, the command-sqeuence about gui-server is processed earlier and process stucks while connecting the device.
    • output.zip
      (53.87 kB, downloaded 130 times, last: )
    • log_7_90.txt
      (7.69 kB, downloaded 95 times, last: )
    The post was edited 2 times, last by n.ehrhardt88 ().
    Does the latest version still show these effects?
    V7.90 is from August 2023 (while we are currently in Feb 2024) and there have been several updates since then.
    segger.com/downloads/jlink/
