I am working with a JLink EDU and SES with a SAMD21 board. I want to use the command line software JLink Commander to go through individual steps like halting the core, setting a breakpoint etc. I have found the basic documentation for the same. It would help me a lot though if there was a tutorial about how to string these commands together. Are there any scripts I can use as a reference?
[SOLVED] JLink Commander - Tutorial
J-Link Commander is designed to be used as a verification tool, to be able to verify that several low-level operations work as expected, independent from an IDE.
It is not designed to replace an IDE or be a full-blown debugger with ELF file debug info support, source-level debug or automated testing.
While some degree of automation is possible with command files is possible:
wiki.segger.com/J-Link_Commander#Batch_processing
it heavily depends on your setup, if that suffice your needs.
For more complex setups and customized actions, there is an SDK available:
segger.com/products/debug-probes/j-link/tools/j-link-sdk/
AlexPlease read the forum rules before posting.
Share
- Facebook 0
- Twitter 0
- Google Plus 0
- Reddit 0
