[SOLVED] JLink-EDU with STM32 issues
  • [SOLVED] JLink-EDU with STM32 issues
    For quite some time I used JLink EDU to flash and debug nRF52 chips, and the setup worked always nicely. Recently, I switched to STM32WLE5JC SoC and now I am facing some challenges:
    1. After several attempts, I managed to make the EDU flash and debug STM32WL only after reducing connection speed to 50KHz! Is this normal?
    2. I though an official ST programmer would improve things, so an STLink-V3NIMIE is now on my desk. In STLINK mode, using the ST utilities, SoC programming works as expected. But I prefer the JLink tools, so I tried to reflash. No luck there, always the following error: "Preparing for FW update (can take up to 10 seconds)...ERROR: Cannot find an ST-LINK, multiple ST-LINKs plugged in, or ST-LINK is in use". FW version is V3J13M4. Has anyone managed to convert an STLink-V3MINIE to JLINK before?
    Your helpis much appreciated.
    Thank you
  • to 1) No
    to 2) The conversion utility only supports ST-LINK V2 on-board. Neither stand-alone ST-LINKs nor ST-LINK V3 in general.
    Edit:
    Note that the STM32WLE5x can operate from 1.8V to 3.6V while the EDU Mini only supports 3.3V targets. Just in case you are not using that MCU in 3.3V mode
  • Thank you for your response.
    STM32 board VCC is 3V3, so that should not be the problem.
    A test with JFlash Lite V7.92n, at a conservative speed of 1000KHz, using signals SWDIO, SWCLK, VIO, GND and RESET, gives the following error:
    Connecting to J-Link...
    Connecting to target...
    ERROR: Could not connect to target.
    Done.
    Repeating the test @ 50KHz succeeds:
    Erasing...
    Done.
    Are there any logs I could attach for troubloshooting?
    Or any other tests to pinpoint the issue?
    Thank you
  • Sorry, no idea so far.
    Still sounds like a setup issue.
    Needing to get down to 50 kHz is quite harsh…
    So there is either a HW defect on the PIOs of the EDU Mini or another HW setup issue.
    I currently do not see any reason on the software side why 50 kHz should make things working while > 1 MHz is totally not working.
    Even 4 MHz is a quite decend speed where timing etc. is all relatively uncritical and even longer cables should not be any issue.
    Finally, a 10K pull-down resistor on the SWDIO line did the trick.
    The speed raised to 2MHz, even with long ugly cables.
    Must be something with the SMT32WLE5 chip or the Wio-E5 module..
    Thanks!
