[SOLVED] Missing memcpy_fast in 7.32
  • [SOLVED] Missing memcpy_fast in 7.32
    Hello Segger Forum,
    I recently upgrated Embedded Studio 7.32 from 5.68 and I found out that the function memcpy_fast was removed from the <string.h> file.
    Is this moved or removed?
    Kind regards,
    Yes, memcopy_fast is not available with the SEGGER Runtime Library.
    The SEGGER Runtime Library provides the standard C API only.
    However, it is optimized for size and performance. In the project options you can select whether to use the small or fast implementation (or an implementation balanced between both).
    The balanced and fast variant will use the fastest implementation of memcpy.
    You can find the setting under Code > Library > Library Optimization
