[ABANDONED] embOS OS-Aware plugin does not appear to work (for me)
  • [ABANDONED] embOS OS-Aware plugin does not appear to work (for me)
    Hey all,
    I'm having difficulty getting the OS aware plugin to work for me. I searched the forums before posting to see if there were any situations that were like mine, but did not see any that were identical.
    I'm working on a Cortex-M0. I don't use an IDE -- I'm using JlinkGDBServer and gdb which connects to it (maybe this is my problem?). First I start gdbserver which looks fine to me so far:
    Command line: -if JTAG -device Cortex-M0+ -speed 500 -rtos /Applications/SEGGER/JLink_V792d/GDBServer/RTOSPlugin_embOS.dylib
    GDBInit file:none
    Terminal I/O port: 2333
    Accept remote connection:yes
    Generate logfile:off
    Verify download: off
    Init regs on start:off
    Silent mode: off
    Single run mode: off
    J-Link Host interface: USB
    J-Link script: none
    J-Link settings file:none
    Target device: Cortex-M0+
    Target device parameters:none
    Target interface:JTAG
    Target interface speed:500kHz
    Target endian: little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link V9 compiled May7 2021 16:26:12
    Hardware: V9.30
    S/N: 609301590
    Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    Checking target voltage...
    Target voltage: 1.80 V
    Listening on TCP/IP port 2331
    Connecting to target...
    J-Link found 1 JTAG device, Total IRLen = 4
    JTAG ID: 0x6BA00477 (Cortex-M0)
    Halting core...
    Connected to target
    Waiting for GDB connection...
    After I start gdb to connect to the server, gdbserver now logs this:
    Connected to 127.0.0.1
    GDB client (conn. 11) requested target.xml from GDB Server
    Reading common registers: Read register 'r0' (4 bytes) from hardware: 0x66EFFFFF
    Read register 'r1' (4 bytes) from hardware: 0x00000000
    Read register 'r2' (4 bytes) from hardware: 0x90C40100
    Read register 'r3' (4 bytes) from hardware: 0x00000000
    Read register 'r4' (4 bytes) from hardware: 0x30CC0100
    Read register 'r5' (4 bytes) from hardware: 0xCDCDCDCD
    Read register 'r6' (4 bytes) from hardware: 0xCDCDCDCD
    Read register 'r7' (4 bytes) from hardware: 0xCDCDCDCD
    Read register 'r8' (4 bytes) from hardware: 0xCDCDCDCD
    Read register 'r9' (4 bytes) from hardware: 0xCDCDCDCD
    Read register 'r10' (4 bytes) from hardware: 0xCDCDCDCD
    Read register 'r11' (4 bytes) from hardware: 0xCDCDCDCD
    Read register 'r12' (4 bytes) from hardware: 0x18000000
    Read register 'sp' (4 bytes) from hardware: 0x40630200
    Read register 'lr' (4 bytes) from hardware: 0xF1840100
    Read register 'pc' (4 bytes) from hardware: 0xC8710100
    Read register 'xpsr' (4 bytes) from hardware: 0x00000061
    Read 2 bytes @ address 0x00011C04 (Data = 0x4B02)
    Read 4 bytes @ address 0x000171C8 (Data = 0x4B02B510)
    Loading RTOS plugin: //Applications/SEGGER/JLink_V792d/GDBServer/RTOSPlugin_embOS.dylib...
    RTOS plugin (API v1.0) loaded successfully
    RTOS plugin: Loaded
    Received symbol: OS_Global (0x0001C490)
    Received symbol: OS_Switch (0x00011F82)
    Received symbol: OS_Switch_End (0x00011F9A)
    All mandatory symbols successfully loaded.
    Downloading 4 bytes @ address 0x00569008
    This sounds great so far. It looks like the plugin loaded successfully. Now when I hit a breakpoint, things don't go as I had expected:
    ...Breakpoint reached @ address 0x00005598
    ERROR: RTOS_UpdateThreads(): Failed to read task name. <------ERROR HERE
    Reading common registers: Read register 'r0' (4 bytes) from hardware: 0x18F90100
    Read register 'r1' (4 bytes) from hardware: 0xB413C3B2
    Read register 'r2' (4 bytes) from hardware: 0x00000000
    Read register 'r3' (4 bytes) from hardware: 0x5F040000
    Read register 'r4' (4 bytes) from hardware: 0x88D70100
    Read register 'r5' (4 bytes) from hardware: 0xFA04A51E
    Read register 'r6' (4 bytes) from hardware: 0x34D80100
    Read register 'r7' (4 bytes) from hardware: 0x18F90100
    Read register 'r12' (4 bytes) from hardware: 0x05000000
    Read register 'sp' (4 bytes) from hardware: 0xD8D60100
    Read register 'lr' (4 bytes) from hardware: 0x65040000
    Read register 'pc' (4 bytes) from hardware: 0x98550000
    Removing breakpoint @ address 0x00005598, Size = 2
    Read 4 bytes @ address 0x00005598 (Data = 0xF7FB4628)
    Reading 64 bytes @ address 0x0001D700
    Read 4 bytes @ address 0x00000464 (Data = 0xB570BD80)
    Read 4 bytes @ address 0x0001D6E8 (Data = 0x0001D788)
    Read 4 bytes @ address 0x0001D6EC (Data = 0x0001D720)
    I am able to see the call stack of the current thread when I type `backtrace`, but aside from that, I am unable to do much besides select various stack frames from the current stack and examine the values of things in scope. Commands like `info threads` do not work in gdb -- it simply shows the current thread and none of the others, however the gdbserver shows something interesting when I ask for a list of all threads:
    Of the 4 addresses above, the first two are addresses of the most recent two functions called in the call stack. The second 2 address are memory addresses of data near the base of the current task (i.e. pCurrentTask within OS_Global). Can anyone please advise on if this is a plugin issue that I can troubleshoot? And if it's not, would someone with knowledge of embOS internals be willing to advise on which registers I can load in gdb to be able to switch to one of the other threads and examine their stack frames? I'd be happy with that too. I'll take whatever I can get. Please help!
    Best,
    Robert
    The post was edited 1 time, last by rhbogart ().
