[SOLVED] Erase all option missing in 7.32
  • [SOLVED] Erase all option missing in 7.32
    Embedded studio version 5.70a has an "Erase All" option available in Project Options->J-Link->Erase All
    I do not see this in version 7.32. Is there another location where this option exists in 7.32? Thanks!
    Indeed the option went missing between versions.
    It should be reintroduced with the next Embedded Studio update.
    To get a notification when it is available you can subscribe here:
    segger.com/notification/subscribe.php?prodid=196
    Out of curiosity, could you elaborate your usecase?
    I assume you are doing some integrity checks in your firmware?
    If that is the case we recommend to work with an image fill value instead of doing a chip erase each time as this will be less tasking on your Flash memory than doing a chip erase every time.
    For more information see here:
    wiki.segger.com/Integrity_chec…_Studio_and_SEGGER_Linker
