[SOLVED] automate flash writing with a command file
  • [SOLVED] automate flash writing with a command file
    I would like to automate the writing of flash. The problem is that the file name to write changes from time to time depending on the version. Is there any way using a parametrized command or script file so that the filename to write becomes a parameter?
    best regards
    Max
  • No. J-Link Commander is not designed for production.
    There are currently no plans to add a command / extension like parameterized command / script.
    You may however create the script on demand, by the caller, depending on the file to program.
  • Just create a program.jlink file with all commands needed, like this with Python or ...
    1. si SWD
    2. speed 4000
    3. connect
    4. loadfile CONFIG_X.hex
    5. loadfile Filename_XY1.hex
    6. loadfile OptionByte_X.hex
    7. rx 500
    8. go
    9. exit
    Call jlink.exe -device XYZ -CommandFile program.jlink
    Of course, interface and speed could be set in command line already.
    You have full control inside (reset and/or run or...) and can change the filename(s) to be flashed here.
    I call this commandfile scripted with a fixed name, but I change the content (filename-hex, config or version) every time before start. I also evaluate the output or log to check for errors (no USB, not properly connected, other write fails due to readout protection still set etc.).
    I do not need a single "loadfile" filename in the command line, that would not be enough in my case. I would need 3 filenames (for DataFlash, Flash and OptionByte), but I like the flexibility of these command files.
    HaJo
