[SOLVED] syntax highligting ino files
    You could try to set the file type to C/C++ by right clicking it in the project explorer window, select Options and go to Code > File > File Type
    I assume you are looking to debug Arduino sketch files, correct?
    If yes we recommend to use Ozone instead as this is the officially supported way by Arduino and SEGGER:
    wiki.segger.com/How_to_debug_A…tch_with_Ozone_and_J-Link
    Just make sure to select "Optimize for Debugging" in your Arduino IDE setup to generate a proper debuggable elf file:
    docs.arduino.cc/software/ide-v2/tutorials/ide-v2-debugger
    Please note that it is board package dependent if that "Optimize for Debugging" is actually doing anything or not. For more information about which boards are supported we recommend to contact Arduino.
