[SOLVED] Accessing peripheral registers via the Console window commands
  • [SOLVED] Accessing peripheral registers via the Console window commands
    Hello, from the Ozone user guide I could see that the CPU registers could be accessed via Target.GetReg(" ") from the console;
    On similiar grounds, what is the command to access the peripheral regsiter's value from the Console?
    Thank you.
  • Hi Skam,
    I guess, Target.GetReg() should also work for peripheral registers. It might be that you need to specify the full "path" for your register, though, i.e. something like "Peripherals/GPIO/GPIOA/MODER". Could you please check if that works for you?
    -- AlexD
  • Hi Alex,
    thanks for your resplonse. Trying out your proposed soluation gave the idea to try out accessing the the peripheral reg like accessing a structure element.
    Taget.GetReg("Peripherals.GPIO.GPIOA.ODR"); //this works
    Attached you will find the console log.
    There is another way to access it, via Target.ReadU32(<peripheral_reg_address>); This works as well.
    Target.ReadU32(0x40020014);
    Thanks again.
    Kind regards
    PS: Just a small thought. Not very important though.
    For Target.GetReg() , the core has to be halted. Hence Debug.Halt(); would be needed beforehand.
    Perhaps it might be a good idea to implement Halt and Continue functions internal to GetReg(). This shall make the GetReg function much faster when these commands need to be automated.
    Thank you :)
    The post was edited 1 time, last by skam ().
  • Hi Skam,
    often there are multiple ways to achieve a desired effect. Since your peripheral registers are memory mapped they may be accessed like memory. That's why reading the memory location works as well.
    The script you create is less portable, though. While the same register may exist in another MCU it might reside at a different address. By using the path name in Target.GetReg() allows your script to execute fine on another MCU, while accessing the memory address may cause tedious update of cryptic hex numbers before making your script work properly on the new MCU,
    -- AlexD
  • Hi Alex,
    unfortunately the proposed access via path didn't work. ("Peripherals/GPIO/GPIOA/ODR"). (pls see attachment)
    Thats why I had to try out the previosly mentioned method. Jfyi.
    Kind regards
  • Hi skam,
    actually, this should work. I guess, reason you did not see it working, might be that I specified "/" as a separator. Instead it should be ".", as you can see in the documentation of that command, which can be found in section 7.9.17.3 in the Ozone user's manual.
    -- AlexD
