[SOLVED] Add peripheral registers to Data Sampling (Data Graph / Timeline) view
  • [SOLVED] Add peripheral registers to Data Sampling (Data Graph / Timeline) view
    Hello, is it somehow possible to add peripheral registers to the data graph (timeline) window for graphical view.
    Thank you.
    [img]https://pbs.twimg.com/media/F39gnTfXIAAQnPE?format=png&name=900x900[/img]
  • Hi skam,
    as long as the peripheral register is memory mapped and accessible, you can add a term such as
    *(unsigned int*)(0x080000000)
    to your Data Sampling window. Of course, you need to replace 0x080000000 with the address of your peripheral register. This should do the trick.
    -- AlexD
  • Hi Alex,
    thanks for your response. This works like a charm.
    Just a small observation. Not very important though.
    You can see that in the 'Data sampling' window I have selected the expression to be displayed in Hex, where as the Timeline data graph by default shown the expression in decimal. I could not find a way to change the display type in the graph. Like said not very important and jfyi.
    Kind regards
  • Hi skam,
    this is intended. Hex numbers are normally interpreted as unsigned, however in the graph window numbers are considered being signed.
    -- AlexD
