[SOLVED] RTT compile error with GCC
  • [SOLVED] RTT compile error with GCC
    I'm a maintainer of TinyUSB project, to ensure the code quality we have some strict GCC flags enabled.
    Wcast-align and Wcast-qual cause SEGGER_RTT.c failed to compile with following error:
    1. e:\mcu\tinyusb\lib\segger_rtt\rtt\segger_rtt.c: In function '_DoInit':
    2. e:\mcu\tinyusb\lib\segger_rtt\rtt\segger_rtt.c:323:10: error: cast discards 'volatile' qualifier from pointer target type [-Werror=cast-qual]
    3. 323 | memset((SEGGER_RTT_CB*)p, 0, sizeof(_SEGGER_RTT)); // Make sure that the RTT CB is always zero initialized.
    4. | ^
    5. compilation terminated due to -Wfatal-errors.
    6. cc1.exe: all warnings being treated as errors
    7. make: *** [Makefile.mk:1269: build/release-BIN1/tinyusb__lib__SEGGER_RTT__RTT__SEGGER_RTT.o] Error 1
    8. e:\mcu\tinyusb\lib\segger_rtt\rtt\segger_rtt.c: In function 'SEGGER_RTT_WriteSkipNoLock':
    9. e:\mcu\tinyusb\lib\segger_rtt\rtt\segger_rtt.c:954:11: error: cast increases required alignment of target type [-Werror=cast-align]
    10. 954 | pRing = (SEGGER_RTT_BUFFER_UP*)((char*)&_SEGGER_RTT.aUp[BufferIndex] + SEGGER_RTT_UNCACHED_OFF); // Access uncached to make sure we see changes made by the J-Link side and all of our changes go into HW directly
    Please either fix them or suppress the error by adding:
    1. #ifdef __GNUC__
    2. #pragma GCC diagnostic ignored "-Wcast-qual"
    3. #pragma GCC diagnostic ignored "-Wcast-align"
    4. #endif
    We will look into this and see if we want to adjust the code to prevent these warnings.
    However, we are currently fully booked with projects and this is the first request regarding this, so I cannot say when we will be able to look into this.
    I would suggest that you suppress these warnings on your side for now, by wrapping the include of the header file in pragmas to disable/enable these warnings.
    Example:
    1. #ifdef __GNUC__
    2. #define SPECIAL_WARNINGS_DISABLE() \
    3. _Pragma("GCC diagnostic push") \
    4. _Pragma("GCC diagnostic ignored \"-Wcast-qual\"") \
    5. _Pragma("GCC diagnostic ignored \"-Wcast-align\"")
    6. #define SPECIAL_WARNINGS_ENABLE() \
    7. _Pragma("GCC diagnostic pop")
    8. #else
    9. #define SPECIAL_WARNINGS_DISABLE()
    10. #define SPECIAL_WARNINGS_ENABLE()
    11. #endif
    12. // [...]
    13. SPECIAL_WARNINGS_DISABLE()
    14. #include "SEGGER_RTT.h"
    15. SPECIAL_WARNINGS_ENABLE()
    That way you can still update the RTT sources without manually adding the pragmas.
