AppWizard Windows Edit Problem
    • AppWizard Windows Edit Problem
      Hi Team,
      In my project need multiple windows on One screen like 10 windows objects on 1 screen. All window sizes same like 400x900. I arrange one window on top of another window. At a time one window is only displayed. Based on my requirements I switch windows. But my problem is whenever I need modification on a particular Window object. I need to move that particular window into TOP and EDIT in app-wizard. Now 10 windows object I will shift. If 30 to 40 windows then I need to shift every time if I want to Edit the window.
      If anyone has any ideas to edit the easy way please give your ideas.
      Thanks Advance
      Ravindhar.S
      You can try the following.
      - Select an object in the hierarchic tree
      - Hold the ALT key on the keyboard
      - Drag the object in the editor window with your mouse
      Alternatively you can select the object in the hierarchic tree and modify its position by editing its properties in the the properties window on the right hand side.
