[ABANDONED] Help opening USB serial link
  • [ABANDONED] Help opening USB serial link
    My goal is to talk to an ARM mmc through a J-Link Segger serial link using this command:
    1. python3 -m serial.tools.miniterm -e /dev/ttyUSB3 115200
    However, I get the following error message:
    No such file or directory: '/dev/ttyUSB3'If I use dmesg, I can see the Segger serial device connected to a usb port (see below):
    1. [159707.574338] usb 1-3: new full-speed USB device number 17 using xhci_hcd
    2. [159707.724537] usb 1-3: New USB device found, idVendor=1366, idProduct=0101, bcdDevice= 1.00
    3. [159707.724542] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    4. [159707.724545] usb 1-3: Product: J-Link
    5. [159707.724546] usb 1-3: Manufacturer: SEGGER[159707.724548] usb 1-3: SerialNumber: 000801025943
    However, I never see anything like, "... FTDI serial link established ..."
    So it looks to me like I am connected to USB3 but that I can't open up a serial link. Also I see this:
    1. USER@USERdev:/dev$ ls -ld ttyU*
    2. ls: cannot access 'ttyU*': No such file or directory
    Any idea as to why I can't open up a serial link?I am running Debian 11.7
    Things I've tried:
    1) install openocd
    2) install python serial link
    3) assigned myself to the dialout group
    Thanks for any help :thumbup: :thumbup: 8o
    __________________
    It's better to add by zero then multiply by it...
  • It’s pretty simple to answer why you cannot connect to the virtual COM port of J-Link:
    Because yours is not configured to expose one…
    (I can see that from the ProductID it enumerates with)
    See here:
    wiki.segger.com/Using_J-Link_VCOM_functionality
  • Thank you for your assessment Alex.
    I am a newbie.
    Maybe I am using the wrong terminology. But in the past, I have used this J-Link device to communicate with my Arm mmc with what I believe was UART over usb (Isn't this called a serial connection?).
    I did this on a RHEL9 machine but now I would like to use the J-Link UART on my Debian laptop. What search terms should I be using to try to replicate the thing that I was able to do before?
    Thank you for your help,
    James
    __________________
  • Hi James,
    VCOM (virtual COM port) is what is used to use J-Link as a virtual com port device.
    This makes it possible to use the related J-Link pins to be used as UART interface.
    The article Alex linked should do exactly what you require:
    Show J-Link as a COM port device, which can then be used by what ever application you are using to send/receive UART information
    between your PC and your target chip.
    For further information please refer to:
    wiki.segger.com/J-Link_Virtual_COM_Port
    For information about how to set it up under Linux, please refer to the article Alex already linked:
  • Newbie or not:
    Did you actually check the link I sent or did you choose to ignore it?
    As I wrote:
    Your J-Link is not configured to expose a virtual COM port but the article describes how to configure it accordingly.
    If you have *really* been using exactly this J-Link before, you either did not use virtual COM port or disabled the virtual COM port of J-Link afterwards.
    So something about your statement of using it previously is either incomplete or incorrect.
