[ABANDONED] J-Link "probe out of memory error"
  • [ABANDONED] J-Link "probe out of memory error"
    Using the J-Link probe to connect to an STM32L062 chip on a custom PCB with SES 7.12a as the IDE, I am now unable to connect the J-Link to the processor, even though this setup has worked previously with no issues. The log for connecting is :
    Connecting ‘J-Link’ using ‘USB 4294967295’
    Loaded C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 7.12a/bin/JLink_x64.dll
    Firmware Version: J-Link ARM V8 compiled Nov 28 2014 13:44:46
    DLL Version: 7.86c
    Hardware Version: V8.00
    Target Voltage: 3.306
    Device "STM32L062K8" selected.
    Current Speed: 4000 kHz
    InitTarget() start
    SWD selected. Executing JTAG -> SWD switching sequence.
    DAP initialized successfully.
    InitTarget() end - Took 20ms
    Found SW-DP with ID 0x0BC11477
    DPv0 detected
    CoreSight SoC-400 or earlier
    AP[0]: AHB-AP (IDR: 0x04770031)
    AP[0]: Core found
    AP[0]: AHB-AP ROM base: 0xF0000000
    CPUID register: 0x410CC601. Implementer code: 0x41 (ARM)
    Found Cortex-M0 r0p1, Little endian.
    Connect fallback: Reset via Reset pin & Connect.
    RESET (pin 15) high, but should be low. Please check target hardware.
    InitTarget() start
    InitTarget() end - Took 19ms
    DPv0 detected
    AP map detection skipped. Manually configured AP map found.
    AP[0]: AHB-AP (IDR: Not set)
    AP[0]: Core found
    Failed to initialize CPU module in firmware because probe is low on memory (heap).
    Failed to connect to target.
    Given that so much activity seems to be happening successfully, it doesn't look like it's a wiring issue between the J-Link and the PCB (I've also tried this on two different boards with the same result). Although the log is complaining about the reset line, we have never attached anything to this pin other than the J-Link before and it hasn't been a problem. The fact that the log says the PROBE is low on memory is what I don't understand. How does the J-Link itself run out of memory, and if it did, why wouldn't unplugging it solve the issue?
  • Can you please post a photo of the J-Link?
    The “USB 4294967295“ looks suspicious…
