[SOLVED] Embedded Studio 7.3.0 : Linking does not work when using RTT/Printf and manual linker script (prinops.c:(.text.libc.vfprintf_l+0x5c): undefined reference to `__SEGGER_RTL_vfprintf')
  • [SOLVED] Embedded Studio 7.3.0 : Linking does not work when using RTT/Printf and manual linker script (prinops.c:(.text.libc.vfprintf_l+0x5c): undefined reference to `__SEGGER_RTL_vfprintf')
    Hello Forum,
    The title sums it up.
    I have a minimal project on a STM32 target (STM32F769I), along with J-Link base connected over JTAG.
    I have a printf call and this seems to cause some linking issues.
    I'm using GCC and a custom linker and startup files provided by STMicroelectronics with their HAL Drivers.
    Thank you !
    Full error message:
    1. C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 7.30/lib/libc_v7em_fpv5_d16_hard_t_le_eabi_balanced.a(prinops.o): in function `vfprintf_l':
    2. prinops.c:(.text.libc.vfprintf_l+0x5c): undefined reference to `__SEGGER_RTL_vfprintf'
    I'm using Segger Embedded Studio v7.3.0
    The recommended way to get started with Embedded Studio is to use the CPU Support Package for your device, create a new project for it and then add your third party sources to it.
    segger.com/products/developmen…o/technology/cpu-support/
    You can even import projects if needed:
    wiki.segger.com/Import_project…CubeMX_to_Embedded_Studio
    Many files e.g. startup files etc. are toolchain specific, so just simply replacing crucial files and hoping it will work is not a good strategy.
    Regarding the error message it is most likely that the library I/O is not set in your project:
    wiki.segger.com/Embedded_Studio_Library_IO
    However as mentioned above we recommend to set up your project differently so such things as printf simply work out of the box.
