[SOLVED] Ubuntu Install and uninstall
  • [SOLVED] Ubuntu Install and uninstall
    Some times ago, Ozone worked well on my Ubuntu machine. After no more use for reasons of Corona, the system was abandoned and cannot connect to target anymore.
    As Ozone shows a big version step from V2.70.5 to V3.30, I decided to take the opportunity to uninstall and start new installation from scratch.
    Following the Ozone User Manual, page 30, chapter 2.1.4 Uninstallation on Linux, I tried the suggested method for Debian systems as Ubuntu should be from that flavour.
    sudo dpkg -remove Ozone
    dpkg: error: conflicting actions -e (--control) and -r (--remove)
    Type dpkg --help for help about installing and deinstalling packages ;
    Use 'apt' or 'aptitude' for user-friendly package management;
    Type dpkg -Dhelp for a list of dpkg debug flag values;
    Type dpkg --force-help for a list of forcing options;
    Type dpkg-deb --help for help about manipulating *.deb files;
    Options marked produce a lot of output - pipe it through 'less' or 'more' !
    jv@JamesWebb:~$
    Changing the options to > sudo dpkg -r Ozone reports hundreds of file missing; assuming package has no files currently installed
    After this, Ozone still worked but dpkg does not know anything about and Ozone is not available in the Gnome Application Manager,
    >dpkg -s Ozone
    >dpkg-query: package 'ozone' is not installed and no information is available
    >Use dpkg --info (= dpkg-deb --info) to examine archive files.
    >dpkg --info Ozone
    >dpkg-deb: error: failed to read archive 'Ozone': No such file or directory
    Assume a case sensitive problem for the package name was also not successfull:
    jv@JamesWebb:~$ sudo apt remove ozone
    Reading package lists... Done
    Building dependency tree... Done
    Reading state information... Done
    E: Unable to locate package ozone
    As Ozone still worked, it can be located well:
    jv@JamesWebb:~$ locate Ozone
    /home/jv/.config/SEGGER/Ozone.conf
    /home/jv/.local/share/Trash/files/Ozone.deb
    /home/jv/.local/share/Trash/files/Ozone_Linux_V270e_x86_64.deb
    /home/jv/.local/share/Trash/info/Ozone.deb.trashinfo
    /home/jv/.local/share/Trash/info/Ozone_Linux_V270e_x86_64.deb.trashinfo
    /home/jv/.local/share/Trash/info/UM08025_Ozone.pdf.trashinfo
    /home/jv/Desktop/UM08025_Ozone.pdf
    /home/jv/Downloads/Ozone_Linux_V330a_x86_64.deb
    /opt/SEGGER/ozone/2.70.5/Ozone
    /opt/SEGGER/ozone/2.70.5/Ozone.png
    /opt/SEGGER/ozone/2.70.5/Doc/ReleaseOzone.html
    /opt/SEGGER/ozone/2.70.5/Doc/UM08025_Ozone.pdf
    /usr/bin/Ozone
    jv@JamesWebb:~$
    Finally I was successful in removing Ozone with
    jv@JamesWebb:~$ sudo apt --purge remove ozone:amd64
    [sudo] password for jv:
    The following packages were automatically installed and are no longer required:
    attr dh-elpa-helper grub-pc-bin libcephfs2 libgfapi0 libgfrpc0 libgfxdr0
    libglusterfs0 libllvm13 libllvm13:i386 librados2 librhash0 python3-dnspython
    python3-gpg python3-markdown python3-requests-toolbelt python3-samba
    python3-tdb tdb-tools
    Use 'sudo apt autoremove' to remove them.
    The following packages will be REMOVED:
    ozone*
    0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
    28 not fully installed or removed.
    After this operation, 57,3 MB disk space will be freed.
    Do you want to continue? [Y/n] y
    dpkg: warning: files list file for package 'libgme0:amd64' missing; assuming package has no files currently installed
    dpkg: warning: files list file for package 'libnet-ssleay-perl:amd64' missing; assuming package has no files currently installed
    dpkg: warning: files list file for package 'fonts-smc' missing; assuming package has no files currently installed
    many many more files .....
    and
    Errors were encountered while processing:
    libreoffice-common
    grub-efi-amd64
    libreoffice-gnome
    gdm3
    libreoffice-l10n-de
    many more ...
    Ozone 2.70 disappeared but I cannot understand what went wrong.
    Jlink V660c is still present, but cannot connect to USB Jlink or JTrace cables.
    Assume the correct installation method is:
    > sudo dpkg ..install ozone.deb
    Is the Jlink installation a prerequisite to use Ozone ?
    What is your prefered method to install / uninstall Jlink / Ozone ?
    The post was edited 1 time, last by Jan_vi ().
  • Hi Jan_vi,
    when testing Ozone on Ubuntu I use the following commands:
    1. sudo apt-get install ./Ozone_Linux_V330a_x86_64.deb
    2. sudo apt-get remove ozone
    On a blank machine J-Link software should be installed before the 1st debug session is started with Ozone. If this is not the case the J-Link/J-Trace may not be found.
    Does that answer your question?
    -- AlexD
  • Thanks, works perfect and should replace the dpkg -remove instructions from the manual.
    There was also a simple trick to connect the target:
    On Windows you have to invoke jlink while Linux works with JLinkExe
    what is not JLink.Exe nor a a Windows Exe file.
    On Linux jlink is the OpenSDK Java Linker what is never successfull in communication with the jlink cable.
