[SOLVED] RTOS Plugin folder missing
  • [SOLVED] RTOS Plugin folder missing
    I installed 3.28e and 3.30 using 64-bit mac installer package, and I can't see RTOS in view menu. Checked under ozone installation folder and there's no Plugin/OS folder.
    I can't check with the older versions I had as I uninstalled it but I'm sure it was there before.
    BR,
    Julien
  • Hi juliengros.
    the folder containing the RTOS plugins is part of the Ozone application package. It can be found in Contents/MacOS/Plugins/OS.
    The view menu does not show an entry for the RTOS until an RTOS plug-in is loaded (see section 6.3.2 of the Ozone user's manual).
    Does that answer your question?
    -- AlexD
