I am hoping that someone finds this problem familiar.
During startup and using an unmodified SystemInit() function in system_LPC13xx.c ...
#if (SYSPLL_SETUP) /* System PLL Setup */
LPC_SYSCON->SYSPLLCTRL = SYSPLLCTRL_Val;
LPC_SYSCON->PDRUNCFG &= ~(1 << 7); /* Power-up SYSPLL */
while (!(LPC_SYSCON->SYSPLLSTAT & 0x01)); /* Wait Until PLL Locked */
#endif
My program is stuck on the instruction "while (!(LPC_SYSCON->SYSPLLSTAT & 0x01))
Checking the assembly code and addresses, doesn't show anything incorrect. The PLL just doesn't indicate Sync'd and Locked.
Both the software and hardware previously worked, but not after I had some tool chain upgrades.
The problem also occurs with the IAR/CMSIS example projects for the LPC13xx.
This all worked under IAR 5.3x running a competitor's hardware and dll.
I upgraded IAR to 6.20 and a Segger J-Link EDU with the latest firmware and dll.
(I also tried IAR-5.50 + Segger J-Link, no difference)
At this time I suspect IDE, library initialization, nxp1313 bootloader or configuration bit issues, or J-Link issues.
The program runs from on-board flash. The SystemInit() function is the first function called from Reset_Handler
As a sanity check, I added code to turn off one of my LEDS before the instruction and another one after the instruction. The LEDs operated properly, so I know I am looking at the right code. The code behaves identically using connected J-Link power and unconnected battery power, so the problem is programmed into the part.
Does anyone have an idea where to look next?
#endif
The post was edited 1 time, last by Hankers ().
