Nuvoton And AppWizard
      Do you want to retrieve the gauge values? You could react on a value change of the gauge. Just add an interaction:
      ID_GAUGE -> VALUE_CHANGED -> SET_VALUE -> ID_TEXT (the object you want to send the value to).
      Then the gauge value will be displayed in a text object (given that decimal mode is enabled for the text object).
      Florian
    • I use this code use for example. But ı dont see in live expression screen the values
      1. void MainTask(void) {
      2. int i=0;
      3. char* getValues[20];
      4. //
      5. // Setup configuration dependent pointers
      6. //
      7. APPW_X_Setup();
      8. //
      9. // Initialize AppWizard
      10. //
      11. APPW_Init(APPW_PROJECT_PATH);
      12. //
      13. // Create all persistent screens except initial screen
      14. //
      15. APPW_CreatePersistentScreens();
      16. //
      17. // Create initial screen...
      18. //
      19. APPW_CreateRoot(APPW_INITIAL_SCREEN, WM_HBKWIN);
      20. //
      21. // ...and keep it alive
      22. //
      23. while (1) {
      24. while (GUI_Exec1()) {
      25. APPW_Exec();
      26. APPW_SetValue(ID_SCREEN_00,ID_PROGBAR_00,i++);
      27. if(i>=100) i=0;
      28. APPW_GetText(ID_SCREEN_00,ID_TEXT_00,getValues[0],5);
      29. }
      30. APPW_Exec();
      31. GUI_X_Delay(5);
      32. }
      33. }
