[SOLVED] Ozone memory window address field missing
  • [SOLVED] Ozone memory window address field missing
    the address entry field in my memory window seems gone missing (see screen shot attached).
    I have not used that for a good while but I am pretty certain it was there at some stage.
    Does anybody have an idea what could cause that?
    I looked through all the "Preferences" but could not find anything.
    What am I missing?
    Kind Regards,
    Hugo
  • Hi Hugo,
    Good to see that you're up and running again.
    this is actually documented in the user's manual, admittedly not too clearly. The option is described in the section for the memory window's context menu. We'll add a note to the section describing the toolbar.
    -- AlexD
