Button animation effect
      AppWizard does not have a feature like this. The closest thing you could do (without user code) is trigger a GIF animation on a button press. The image object would be at the same position as the button while the button itself is invisible. But of course, the GIF animation would be static. The ripple effect wouldn't change dynamically to where the button was touched.
      If you want to create a ripple effect that takes the touch position into account, you would have to manually implement this through user code.
      Florian
