[SOLVED] PageSize of FlashDevice
  • [SOLVED] PageSize of FlashDevice
    From SEGGER_Flash_Loader, the PageSize is meant that "This field describes in what chunks J-Link feeds the flash loader. The SEGGER_FL_Program() function will be called with a data chunk of multiple of <PageSize> bytes"
    The NumByte of SEGGER_FL_Program() will be SectSize of FlashDevice and SEGGER_FL_Verify() will be the SectSize or PageSize of FlashDevice randomly. Is it normal? Thanks.
    1. #define FLASH_PAGE_SIZE 0x00000100 // 256 Bytes
    2. #define FLASH_SECTOR_SIZE 0x00001000 // 4096 Bytes
    3. struct FlashDevice
    4. {
    5. U16 AlgoVer;
    6. U8 Name[128];
    7. U16 Type;
    8. U32 BaseAddr;
    9. U32 TotalSize;
    10. U32 PageSize;
    11. U32 Reserved;
    12. U8 ErasedVal;
    13. U32 TimeoutProg;
    14. U32 TimeoutErase;
    15. struct SECTOR_INFO SectorInfo[MAX_NUM_SECTORS];
    16. };
    17. struct FlashDevice const FlashDevice __attribute__((section("DevDscr"))) = {
    18. 0x0101,
    19. "MYTest",
    20. 1,
    21. 0x10000,
    22. 0x80000,
    23. FLASH_PAGE_SIZE,
    24. 0, // Reserved, must be 0
    25. 0xff,
    26. 1000000,
    27. 10000,
    28. FLASH_SECTOR_SIZE, 0x00000000,
    29. 0xFFFFFFFF, 0xFFFFFFFF
    30. };
    The post was edited 2 times, last by sharon ().
  • Hello Sharon,
    Not sure if I understand you correctly.
    For SEGGER_FL_Program(), <NumBytes> is guaranteed to be a multiple of FlashDevice.PageSize
    For SEGGER_FL_Verify(), there are no guarantees what <NumBytes> will be. The J-Link software is allowed to verify in chunks whatever it likes to.
  • Hi Alex,
    For SEGGER_FL_Program(), <NumBytes> is guaranteed to be a multiple of FlashDevice.PageSize => But I do get the NumBytes as FlashDevice.SectorInfo[0].SectorSize instead of FlashDevice.PageSize, is it normal?
  • Hi Sharon,
    The answer if it is "normal" is basically yes.
    As SectorInfo[0].SectorSize == 0x1000 (4 KB)
    and PageSize = 0x100 (256 bytes)
    and SectorSize = 16 * PageSize, a multiple of PageSize is passed to SEGGER_FL_Program() so what the J-Link software does is allowed and within the spec.
