[SOLVED] Freertos: Call stack for selected task?
  • [SOLVED] Freertos: Call stack for selected task?
    I have exactly the same needs as this post:
    With program halted, I would like to see the call stack for any freeRTOS task.
    The thing is, when I click on a task in FreeRTOS window, nothing change in the call stack window.
    I'm using Ozone 3.28b on linux and I loaded this module :
    Project.SetOSPlugin ("FreeRTOSPlugin_CM4");
    which I'm sure is the js one because if I edit it (/opt/SEGGER/Ozone_V328b/plugins/OS/FreeRTOSPlugin_CM4.js) and add a custom
    column, I can see it in the window.
    What should I do?
    I'm using STM32L4.
    Julien
  • Hi Julien
    please switch to the current version of Ozone, i.e. 3.28d. A fix targeting potential flaws in call stack reconstruction was released lately, please refer to the release notes for details.
    In general we recommend always using the latest Ozone version in order to make benefit of the improvements and corrections SEGGER provides.
    Does that solve your problem?
    -- AlexD
  • Hi Julien,
    you're very welcome.
    -- AlexD
