[SOLVED] Is it possible to use VCOM over Ethernet (J-Link PRO)
  • [SOLVED] Is it possible to use VCOM over Ethernet (J-Link PRO)
    I have a target that makes use of the J-Link's Virtual COM Port feature (in particular, Rx.) It works fantastically when the J-Link is attached to a host via the USB interface. However, I'm in a situation now where I'm needing to access the VCOM while the J-Link is connected to the host via the network.
    I've not found anything in the documentation or in any of the tools (nor J-Link Commander) that look to expose that functionality anywhere. Is it there and I'm just missing it?
    I can absolutely understand if the VCOM functionality (as in, full USB CDC-ACM) isn't available via the network, but I do hope there's at least a way to read & write through some other interface. (Be it a TCP (or other) socket, or over the J-Link network protocol itself.)
    As you correctly pointed out, VCOM uses the USB CDC-ACM class which is USB specific and therefore not available over Ethernet.
    There are J-Link API functions that may be used to access the VCOM channel (of course not concurrently with a terminal application on the host. They are mutually exclusive)
    The J-Link API description is part of the SDK: shop.segger.com/debug-trace-pr…ftware-add-ons/j-link-sdk
