My project periodically will have the target checking for potential data coming from the host without making a blocking call, though USBD_BULK_ReadAsync() or USBD_BULK_ReadOverlapped() could be used I first tested the API by using the function USBD_BULK_GetNumBytesInBuffer(). This was made by a simple modification to the USB_BULK_Test.c code provided for the NXP 1060 EVK. Is there some kind of initialization missing or should this function return 1 (one) after the corresponding eval code for the host is running and the device has been selected? I always see a 0 (zero) being returned.
USBD_BULK_GetNumBytesInBuffer() always returning 0
The function USBD_BULK_GetNumBytesInBuffer() never triggers a read, it only check for bytes in the buffer. If you never call any read function, then the buffer will be always empty.
Please use USBD_BULK_Receive(..., Timeout = -1) instead.Please read the forum rules before posting.
Or you can contact us via e-mail. -
Thank you Rainer for the info. I have tried the following an none give me an indication that there is a byte or more available to read:
USBD_BULK_Receive( hInst, NULL, 0, -1 );
USBD_BULK_Receive( hInst, NULL, 1, -1 );
USBD_BULK_Receive( hInst, &c, 0, -1 );
My workaround has been using a 1mS timeout so not to waste too much time with USB_BULK_Read(), but from what I can understand from the manual is that this can cause loss of data if a timeout expires before a transaction has completed..
Still need your help, thanks.The post was edited 1 time, last by adam_sds ().
Update, so long as I only call the USBD_BULK_Receive( hInst, NULL, 0, -1 ) once in the loop (till I later receive something) then USBD_BULK_GetNumBytesInBuffer() will actually return the number of bytes in the OUT buffer that are waiting to be read, then I call USBD_BULK_Read() to get them and reset a flag to allow the process to restart..
Simply call USBD_BULK_Receive( hInst, &c, 1, -1 );
It returns 1, if you got a byte,
It returns 0 if there is no data.Please read the forum rules before posting.
Share
- Facebook 0
- Twitter 0
- Google Plus 0
- Reddit 0
