[SOLVED] Integrating SystemView Sources for Renesas RX controllers
  • [SOLVED] Integrating SystemView Sources for Renesas RX controllers
    Dear SEGGER Team
    When I integrated the SEGGER RTT + SystemView sources into my FreeRTOS project, I found something I couldn't understand at first sight.
    My application runs on a Renesas RX target, compiled with the CCRX Compiler package.
    My application has some very strict real-time requirements, hence there are a few interrupts that shall not block under any circumstance. The SEGGER_RTT_LOCK blocks all interrupts by clearing the global interrupt enable in the PSW (Processor Status Word, see SEGGER_RTT_Conf.h).
    Therefore I had to re-implement the SEGGER_RTT_LOCK in the following way:
    Source Code: SEGGER_RTT_Conf.h
    1. #define SEGGER_RTT_LOCK() { \
    2. unsigned long _SEGGER_RTT__LockState; \
    3. _SEGGER_RTT__LockState = get_ipl(); \
    4. set_ipl(configMAX_SYSCALL_INTERRUPT_PRIORITY);
    5. #define SEGGER_RTT_UNLOCK() set_ipl(_SEGGER_RTT__LockState); \
    6. }
    What this does is pretty simple. Only interrupts that access the FreeRTOS API are masked. This is very similar to how it is done for some ARM-based devices.
    However, this leads to bad behavior in the following code:
    Source Code: SEGGER_SYSVIEW.c
    1. void SEGGER_SYSVIEW_RecordEnterISR(void) {
    2. unsigned v;
    3. U8* pPayload;
    4. U8* pPayloadStart;
    5. RECORD_START(SEGGER_SYSVIEW_INFO_SIZE + SEGGER_SYSVIEW_QUANTA_U32);
    6. //
    7. pPayload = pPayloadStart;
    8. v = SEGGER_SYSVIEW_GET_INTERRUPT_ID();
    9. ENCODE_U32(pPayload, v);
    10. _SendPacket(pPayloadStart, pPayload, SYSVIEW_EVTID_ISR_ENTER);
    11. RECORD_END();
    12. }
    To identify the current interrupt, SystemView needs to know the interrupt level.
    RECORD_START calls SEGGER_RTT_LOCK. Unfortunately, this call leverages the interrupt level (in my example up until "configMAX_SYSCALL_INTERRUPT_PRIORITY"). It is only after this call that the *current* interrupt level gets stored in the variable "v".
    Example:
    • Interrupt X has priority 1
    • X gets traced => priority gets leveraged to 4
    • v = 4
    • SystemView receives this trace with the wrong interrupt level.
    The workaround I implemented is to place the line v = SEGGER_SYSVIEW_GET_INTERRUPT_ID(); just above RECORD_START(SEGGER_SYSVIEW_INFO_SIZE + SEGGER_SYSVIEW_QUANTA_U32);.
    Did I miss anything or was my correction the right choice?
    As a follow-up question:
    Is there another way to identify interrupts? I have several interrupts that run on the same priority. Thus they cannot be differentiated.
    Any answer would be highly appreciated.
    Kind regards,
    Matthias Schär
  • Hello Matthias,
    is this matter resolved? Because in your other thread you wrote that you were able to instrument your application as documented.
