[SOLVED] Disable dialog for target's reboots
  • [SOLVED] Disable dialog for target's reboots
    Hey all,
    I'm debugging some issue and in order to reproduce it I have to reboot unit many times (up to 400 times) until problem happens.
    I'm using AfterTargetDisconnect() to reconnect to the device.
    1. void AfterTargetDisconnect (void) {
    2. Util.Log("AfterTargetDisconnect");
    3. Debug.Connect();
    4. }
    The only issue I have right now is that as soon as device reboots Ozone shows a modal dialog saying "Failed to read target status. Abort Debug Session?" and I have to press "Yes" each time which is a bit annoying.
    Is there a way to suppress this dialog or the only option I have is either to patch the binary or write a X Windows clicker to do press this button for me?
    TIA.
    Alex.
  • Hi dev_alexz,
    right now there is no way to disable this dialog.
    -- AlexD
