[SOLVED] Returning to the last visited line
  • [SOLVED] Returning to the last visited line
    I am used to use ALT+left/right arrow to move between the last visited lines in Eclipse. What is the corresponding keyboard shortcut should be used during Segger.
    note: Alt+left arrow works in Segger during the debugging session only.
    another question, is there a link for the general keyboard shortcuts used in Segger in windows environment?
  • Hello MAmer.
    Jumping to the last visited lines in Embedded Studio is not available.
    Alt+left let you jump to the last created waypoint, which will be created if you jump to e.g a function declaration.
    During debugging, constantly waypoints are generated, but this shortcut also works in the code editor.
    You can find all available keyboard shortcuts in Embedded Studio via: Help -> Keyboard Map...
    Best Regards,
    Lucas
    Our engineers will try to answer your questions between their projects if possible but this can be delayed by longerperiods of time.
    Should you be entitled to support you can contact us via our support system: segger.com/ticket
