[SOLVED] SystemView _VPrintHost string format support
  • [SOLVED] SystemView _VPrintHost string format support
    Hi Segger Team,
    we're having software that passes printf format strings with %s in the format string and we want to be able to pass this trough SystemView too (RTT already does support it).
    Currently we do patch the SystemView sources right now in the following way.
    EDIT:
    One thing to mention here is that %s format string then would only be working when formatted on target.
    Host functions only work liek expected with such format string when SEGGER_SYSVIEW_PRINTF_IMPLICIT_FORMAT is set.
    When disabled (default) the PC software does receives the format string with the %s and the char* converted to an integer.
    Then the behavior is the same like right now when using Host functions with a %s
    We also created a patch file: VPrintTarget-string-formatting.zip
    Be aware that this also includes the string NULL check discusses for RTT in this thread.
    It would be nice, if this patch could get part of the official SystemView release.
    Philipp Häfele
    The post was edited 1 time, last by ifmPhilipp ().
  • Hello Phillip,
    Thank you for sharing.
    On first glance this looks good.
    We will run some tests on it and if everything passes it will most likely be added to the official release.
  • Hi Nino,
    sounds great.
    You maybe want to add the discussed "(null)" printing discussed in SEGGER_RTT_vprintf / SEGGER_RTT_printf string format NULL check
    1. if(s == NULL) {
    2. _StoreChar(&BufferDesc, '(');
    3. _StoreChar(&BufferDesc, 'n');
    4. _StoreChar(&BufferDesc, 'u');
    5. _StoreChar(&BufferDesc, 'l');
    6. _StoreChar(&BufferDesc, 'l');
    7. _StoreChar(&BufferDesc, ')');
    8. break;
    9. }
    Philipp
    The post was edited 1 time, last by ifmPhilipp: characters need to be in single quotes instead of double onces " => ' ().
