[SOLVED] Questions about jtrace and ozone
  • [SOLVED] Questions about jtrace and ozone
    Hello everyone,
    Currently, I'm using JTrace and Ozone for my project to measure execution time automation base on jlinkscript, I have some question relate to it, please help
    1. How can I start or stop tracing application in C code?
    2. How to measure execution time of functions and sub-functions in application (bare metal application)?
    For Ex : I have a function like this,
    1. void FunctionC()
    2. {
    3. ..........
    4. }
    5. void FunctionB()
    6. {
    7. FunctionC();
    8. }
    9. void FunctionA()
    10. {
    11. FunctionB();
    12. }
    13. int main (void)
    14. {
    15. FunctionA();
    16. return 0;
    17. }
    I can export log of execution time for functions A, B, C. But how can I create a log with call graph in jlinkscrip? like below
    ----FunctionA 10ns
    -------- FunctionB 5ns
    ------------FunctionC 2ns
    3. How can I open full call graph of functions?
    Thank you,
    Tuan
    The post was edited 2 times, last by tuandt2 ().
  • Hello Tuan,
    Could you provide your S/N of the J-Trace for reference?
    Regarding 1: You don't. Why would you need to do that? Is something not working?
    2: If available with timestamps. Which target device are you tracing exactly?
    JLinkScript would be the wrong place as the high level analysis is done in Ozone. What is your use case here?
    3: Not sure what you mean. But we have the timeline window which will show you the complete recorded call stack over time.
    To get used to J-Trace and Ozone we recommend our trace tutorial so you can try out all features in a already working and set up environment:
    segger.com/products/developmen…ogy/ozone-trace-tutorial/
    Thank you for your feedback, I found the solution for our project with items in previous post.
    And btw, I have another question about ozone, please give me a idea. I'm trying to debug a i.MX8QM chip and I saw in setup of Ozone v3.28 supported for IMX8QM, so I did some setup based on setup wizard such as Device, Core, Elf file. After finishing configuration, I select "Download and reset Program" but only debug symbol in elf file is loaded to Ozone, and binary code didn't program to memory of chip. And I added a function to load binary file in TargetDownload handler.
    1. void TargetDownload (void) {
    2. // Clear memory that contain the binary
    3. Target.FillMemory(0x88000000, 1048576, 0);
    4. // Load bin file to memory at address 0x88000000 (0x88000000 is run address and get from map file)
    5. Target.LoadMemory("D:/CORE0.elf.bin", 0x88000000);
    6. }
    So, select the elf file at configuration time doesn't include program the memory, doesn't it? But, it quite strange, I used the example board in Jtrace package, with the same step to setup, when I click "Download and reset Program", it downloaded the binary file to memory . Please give me a explain about this, I read the document but haven't found the solution yet.
    Thank you
    This is a new question that is unrelated to the posts topic.
    Please open a new thread for a new question.
