[SOLVED] Active read and/or write protection pop-up window
  • [SOLVED] Active read and/or write protection pop-up window
    Is there any way to handle the read/write protection pop up window in a JLink commander script? It is quite annoying that instead of having that question appear in the terminal, it comes up as a pop up.
    And I want a way in my Jlink script to answer "No", or ensure it is "No" if a user has remembered selected action as "Yes"
  • Showing it in a terminal is not doable because it would completely hide it in all IDEs and the majority of customers are happy about the dialog because 95% of the time they lock their chips by accident and would not even realize that they did things wrong, without that dialog.
    There is no way to issue a „no“ selection via a script if the user selected „yes + remember“, as it would not make sense to have a remember option if it would be ignored anyhow…
    What you can do is adding your own script that includes a InitTarget() and SetupTarget() function. This will override the default script of the software (the ones that shows the dialog and does the unlock logic).
  • Thanks Alex.
    Are there any website links that you can point me towards that could give some examples and/or guidance on developing ones own scripts with the InitTarget() and SetupTarget() functions?
    Yes there is:
    wiki.segger.com/J-Link_script_files
